Silvertop distributor
Postby Lloyd » Thu Apr 14, 2005 9:05 pm
Hey people, I'm planning on a silvertop head to go onto my GZE block and as basically using the rest of the GZE running gear, ECU etc.
Problem I've struck is that with the silvertop head on I cant use the cam angle sensor from the GZE head. Now the silvertop distributor has (once the rotor is removed) the correct number of teeth on the rev signal wheel with a single pick up just like the GZE. Likewise with the signal for the coils to throw out a spark or two. Both are 4 wire out but the plugs are different and I was wondering if anyone has swapped the plugs and basically used half of the silvertop distributor as a cam angle sensor and if so then could you please identify which wires corrospond to which other wires from the GZE plug.
Long shot I know, but I can probably just muck around and work it out myself. Thought it might be easier if someone has done it and provide info for anyone else planning on doing the same thing.
Chur
