Car has no tacho, but want.
Postby MrBeef » Tue Apr 19, 2005 12:46 pm
hi there.
My car '92 corolla 1.6XL does not have a tachometer.
I want a tachometer.
I am wondering, will my car have the wires needed for the installation. And if they need to be installed where exactly does each wire goto etc etc.
Any last words?
Box, toaster, Aluminum, Maple syrup...no I take that back..im'a hold onto that one.
My beast!
MrBeef
Postby Ebola_One » Tue Apr 19, 2005 1:12 pm
You will be able to run one, from memory you'll need to run the tacho signal wire from the earth wire on the coil (there should be several places on the one terminal to use)
Dirty DA Duz 14.4's, 48's (Taupo) & 1:25's (Manfield)
Ebola_One
TS Wannabe
Postby pervert » Tue Apr 19, 2005 1:25 pm
Easy as job, 4 wires for aftermarket tachos.
1 to the coil.
1 to earth.
1 to power.
1 to light source.
Will work fine on your car.
pervert
Postby MrBeef » Tue Apr 19, 2005 7:21 pm
is there already a wire coming off the coil for me to attach to?
Any last words?
My beast!
MrBeef
Postby TRDWGN » Tue Apr 19, 2005 7:27 pm
get a GL spec dash with factory tacho, should just plug straight in and work, i did it on a AE80 no problems so can't see why it should be different
TRDWGN
Postby Lloyd » Tue Apr 19, 2005 7:29 pm
Just tap into the wire coming off the negative of the coil (usually negative, just check first).
