I need help,please....silvertop with blacktop ecu.
Postby gt20v » Tue Apr 19, 2005 4:23 pm
hi guys,
finish done the wiring with blacktop ecu in place of the silvertop ecu.
car started find...everything fine except i cant half throttle at all.The engine like cant go at all..i cant explain except that when in mid throttle,like the fuel doesnt go to the engine.
When i bump the pressure to a whooping 60psi....then the engine will not show a very big the brrr...brrrr effect...
is the O2 problem?
gt20v
Postby Ebola_One » Wed Apr 20, 2005 9:27 am
Oh dear god... what were you thinking!
The silvertop & Blacktop run completely different air sensors.
Silvertop runs a flap type Air Flow Meter, the Blacktop runs a MAP sensor.
Get hold of a Map sensor, remove the AFM, there'll be plenty of other little sensors you'll need to get frmo a blacktop as well, as there are things like air temp sensors in the AFM (on a ST)
Why did you change the ecu over?
Dirty DA Duz 14.4's, 48's (Taupo) & 1:25's (Manfield)
Ebola_One
TS Wannabe
Postby gt20v » Wed Apr 20, 2005 5:33 pm
hahaha of coz i know they are different.
thats why i have to change the ecu,wiring and sensor to ditch the AFM...
now thats the problem..
anyone help me???
does the blacktop O2 sensor is needed too??
gt20v
Postby MetalupYoAss » Wed Apr 20, 2005 10:38 pm
It might be something to do with the VVT kicking over, i think the function is different between silver and black
MetalupYoAss
Postby sergei » Wed Apr 20, 2005 11:15 pm
VVT is not really different, I run black top cams on silver top engine/ecu with black top VVT pulley, can't say they different except black top one is quieter....
but black ecu top switches off the VVT earlier then silvertop ecu (6800 vs 7600rpms)...
Postby sergei » Wed Apr 20, 2005 11:20 pm
check your cam timing, you might be off by one tooth... also where did you hook up the map sensor, if in same place as FPR it is a very wrong place, there is a tube going on other side of the manifold, near fat from idle control solenoid, in fact it is just next to it, put a T in it and run map sensor from it, + don't forget to use damper (plastic cylinder which goes inline with MAP)
Postby JT » Thu Apr 21, 2005 3:12 pm
sergei wrote:VVT is not really different, I run black top cams on silver top engine/ecu with black top VVT pulley, can't say they different except black top one is quieter....
Ehh, the blacktop ecu switches vvt off 1200rpm from redline? I know the silvertop is around what you say as I've had a light hooked up but I don't remember seeing my mates blacktop switch off at 6800.
JT
Postby gt20v » Fri Apr 22, 2005 10:16 pm
emmm why does the cam timing off??
i didnt open the cam pully....
anyway.....i tried use the FPR vac source.......its the same thing happen....the other side vac source tried too.....even make a connection btw the FPR and the other side vac also no use...
can i know is it bcoz of the vac source??ive check the ecu.no problem.
the only thing is either vac or TPS or O2 sensor......??
gt20v
Postby gt20v » Sun Apr 24, 2005 4:31 am
anyone??
gt20v
Users browsing this forum: Bing [Bot] and 23 guests
