KP** Diff
KP** Diff
Postby ee904age » Tue Apr 19, 2005 10:40 pm
What diff would fit a KP** without too much fabrication? Needs to have discs available if not there already and take about 210kw reliably, oh and no single spinners of course.
Shay
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby wde_bdy » Tue Apr 19, 2005 11:16 pm
Pretty much anything will fit once you transfer mounts and shorten the housing. There are no easy upgrades for that sort of power. Hilux is one option, or Borgwarner from Falcon, Commodore etc (may only have to shorten one axle with this setup).
Callum
wde_bdy
Postby TygerTung » Tue Apr 19, 2005 11:22 pm
Any idea on one for a KE36 which won't need shortening, just the mounts transferred?
TygerTung
Postby wde_bdy » Tue Apr 19, 2005 11:32 pm
TygerTung wrote:Any idea on one for a KE36 which won't need shortening, just the mounts transferred?
Depends on power goals, LSD etc. T series from a TE71 or similar T series Corolla, maybe a Corona diff with FWD offset wheels. Have also seen a Nissan Gazelle(???) I think it was diff in a KE36 with factory LSD and discs.
Callum
wde_bdy
Postby l1ttle_d3vil » Tue Apr 19, 2005 11:40 pm
ive heard that ae86 diffs will fit straight in without needing to be shortened - just mounts changed (obviously).
ive got an ae85 LSD that im going to put into my KE35 so will know whether this is true or not once that goes in - that wont be for a while yet though. (im pretty sure ae85 and ae86 diffs are the same width etc (141cm), so if one fits the other should...)
Users browsing this forum: Bing [Bot] and 20 guests
