4AGE 16V and 4AGZE Alternator differences?
Postby aesc » Fri Apr 22, 2005 1:39 pm
Hi,
Just wondering if anyone can tell me the differences in the above? Iv seen pics of them both and they look very similar and pulleys both are 5PK etc. Do the mounting points line up ok? Anything anyone could tell me would be good.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby 1598cc » Fri Apr 22, 2005 3:27 pm
4agze one is similar. i used a 4age one and it bolted up , but i had to reroute the belt as the top mounting hole is sorta opposite to the 4agze eg its 5cmish to the left and the other one to the right.. hard to explain. connectors etc are all the same
1598cc
Postby aesc » Fri Apr 22, 2005 4:31 pm
1598cc wrote:4agze one is similar. i used a 4age one and it bolted up , but i had to reroute the belt as the top mounting hole is sorta opposite to the 4agze eg its 5cmish to the left and the other one to the right.. hard to explain. connectors etc are all the same
Oh i see, i think i know what your saying. So really it will sit further towards the front of the car than the 4agze one does ie to the right say 5cm? Did you have to use a slightly larger belt at all?
How possible would it be just to transfer the internals between the two alternators? Or is part of them a sealed unit?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby evil_si » Fri Apr 22, 2005 10:29 pm
they are different
the 4agze has a wider base mounting bracket by about 8mm, and unless you can modify the alternator it wont fit.
evil_si
Postby neon_spork » Sat Apr 23, 2005 12:05 am
From memory the pulley on the 4agze alternator sticks out further than the 4age one also.
Most of the internals are interchangable, but obviously the shaft is longer in the 4agze alt and I dont think you can eaily get the windings out.
So if its just the brushes or electronics in you gze alt that are cooked you can rebuild it using parts from a different alternator
neon_spork
Postby aesc » Mon Apr 25, 2005 8:15 pm
Thanks for your replies guys.
Looks like ill be pulling the pin on it :lol:
EX AE101 owner
2013 Ford Focus ST
aesc
Postby evil_si » Mon Apr 25, 2005 8:34 pm
what were u wanting to do?
evil_si
Postby aesc » Mon Apr 25, 2005 10:48 pm
evil_si wrote:what were u wanting to do?
Theres a brand new alternator off a 4age on trademe going at the moment, thought i could buy it and use it on my gtz as a direct replacement. my alternator doesnt seem to charge all that efficiently, so yeah
EX AE101 owner
2013 Ford Focus ST
aesc
Users browsing this forum: Bing [Bot] and 21 guests
