Fuel Filter
Fuel Filter
Postby BZG Wagon » Sat Apr 23, 2005 7:07 pm
Could someone post a pic of the location for the fuel filter on an AE101 Black Top. Are they hard to replace?
BZG Wagon
Postby Lloyd » Sat Apr 23, 2005 7:11 pm
Should be 2 lines from your fuel rail, one goes to the tank and one goes to the fuel filter. Probably located on the firewall slightly to the passengers side of the car. Not too bad to replace, just undo it from the lines going to it (probably one on top and one underneath) and remove the mounting bracket.
Postby neon_spork » Sat Apr 23, 2005 7:50 pm
I hate fuel filters, atlest the ones on AE92's The fuel line on the bottom of the filter alwyas seems to be done up super tight and impossible to get at.
neon_spork
Postby Bling » Sat Apr 23, 2005 8:17 pm
not too hard to replace....
just get a new filter, then you'll be able to easily spot your current one by comparing the two :P
Postby LEV_101 » Sat Apr 23, 2005 10:02 pm
i just changed my fuel filter on my silvertop 20v... the bottom was so hard to un screw ... had to take it to a garage to fit it ... cost 40 bucks :( ... i do not recommen changing by yourself...
LEV_101
Postby Bling » Sat Apr 23, 2005 10:44 pm
Yea I had a similar problem with undoing the bottom of mine, just thought it was mine tho, took me ages :P maybe its not just mine that was insanely tight... :roll:
Postby B_giB » Sun Apr 24, 2005 1:18 pm
left front wheel needs to come off to make it easier.
its quite low in the engine bay, and you need flair nut spanner
LEV_101 wrote:i just changed my fuel filter on my silvertop 20v... the bottom was so hard to un screw ... had to take it to a garage to fit it ... cost 40 bucks :( ... i do not recommen changing by yourself...
i did mine a while ago, quite hard on 101's (or maybe im just inept) :oops:
Mr OIZO came and rescued me, cheers mate
Current: SXE10 Altezza
Previous:AE86 Trueno Notch Back: Gone but not forgotten :cry: :(
AE101 Levin 20V super strut
1994 Mercedes Benz C280 Sport
B_giB
Users browsing this forum: Bing [Bot] and 24 guests
