Clutch help please
Clutch help please
Postby Gx71man » Sun Apr 24, 2005 3:37 am
Im putting in the 1jz, Everything is almost sorted Except for the clutch.
I have a flywheel and clutch plate. Now i need the pressure plate.
Does anybody no the differance in the clutch setup from a 2jzge (w55) I guess To a R154?? I am stuck.
I was thinking of using a higher lb pressure plate off a 2jzge, Or wont it cut it??
Would the pressure plates work the same way?? Or are they totaly different.
Sorry if it sounds like a noob question, I am a goober at writing stuff up.
Thanks
Sean
I Give My Mrs A 1/4 inch at a time, For those ten seconds or less Im Free...
Gx71man
