Stealer Of Souls wrote:Alternator isn't falling over. It handles fine (pump on adds 6A at max flow...).
It's cause my heater doesn't work very well anymore (flow issues due to electric waterpump) and I was wondering how to fix it.
I had two real options. A separate little water pump to circulate water through the heater core or making up some form of electric heater. I was thinking of the electric heater option but would have to get a bigger alternator to stand up to the potential current draw.
So this is just a pricing check.
ee904age wrote:Civic Wholesale stock a wide range of new aftermarket alternators, most models come in a range of outputs. I havent got any contact details for them anymore but Im sure you can find a number somewhere.
matt dunn wrote:Electric heaters are a waste of time.
The only effective one I've seen was on a SAME tractor that was air cooled.
It has it's own alternator to run it and drew just under 100A to make hot air. It had to have battery cables running to and from the element.
If your elec water pump doesn't flow enough to run water thru the heater, does it flow enough thru the engine?
