Running 3S-GTE without an Intercooler
Postby Corona » Fri Apr 29, 2005 1:48 pm
Hi All,
I am hopefully going to get the GTE in the Corona running in the next day and was wondering.
As I don’t have an Intercooler sorted out for the beast yet, is it safe to run without one at the moment? I was thinking of just running a pipe from the turbo outlet to the manifold inlet until I can find an intercooler that suits, and putting in some octane booster to try to eliminate the detonation that is likely to occur.
But before I went and did this, I thought that I would ask the Gurus here :)
Just remember: The glass is neither half full nor half empty, it is merely the wrong size
Corona
Postby Dell'Orto » Fri Apr 29, 2005 2:43 pm
Well, if you can keep boost levels to maybe 7psi and dont fang it, I dont see it causing much harm.
Have a look on trade me for a stock MR2 intercooler, they pop up often and will do the job for like $30 until you can get a proper one.
Postby RomanV » Fri Apr 29, 2005 3:27 pm
Is that chicken man's old corona you are talking about?
If so, good to hear it might finally be running soon. :)
Postby Corona » Fri Apr 29, 2005 4:18 pm
RomanV wrote:Is that chicken man's old corona you are talking about?
The very same. Been working on it all week, and am just wireing up the Engine fues box as I type. (Well not as I type, as I am am having a coffee at the moment, but "should" hopefully have it going by today or tomorrow :D )
The engine is still stock at the moment, so will just have to drive mostly like a nana untill I get this intercooler sorted out then eh?
Corona
Postby GT4 20 » Fri Apr 29, 2005 6:39 pm
As Boost says, keep max pressure to around 6 - 7psi and you should be okay.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Malcolm » Fri Apr 29, 2005 6:52 pm
should be ok, I think you should go for an ST165 intercooler, will be very stealthy :)
I have one if you want to buy it, no pump but I have the IC, some pipes, and a heat exchanger. All yours for $150 :)
