Inane wrote:however, boost controller wise
pitfalls are =
-car wont run low boost while warming up, so you need to make even more certain the car is warmed up before planting boot.
EVLGTZ wrote:Inane wrote:however, boost controller wise
pitfalls are =
why wouldn't it run low boost if it hadn't warmed up?
Surely the boost controller will control boost regardless of engine temp.
I know mine does.
Inane wrote:-you will be tempted to run more boost (especially if your mistery mind controlling NEED-MORE-BOOST plug is connected.)
Zomb wrote:you have it around the wrong way. When you install a boost controller you dissable the T-VSV. So when the boost control is truned right down it will boost the lower factory boost setting.
Inane wrote:in fact a decent boost controller, will allow your boost to stop at or go up to wherever you want it to!
fivebob wrote:Inane wrote:in fact a decent boost controller, will allow your boost to stop at or go up to wherever you want it to!
Only to the actuation pressure of the wastegate which on the Stock engine is 7psi.
Inane wrote:fivebob wrote:Inane wrote:in fact a decent boost controller, will allow your boost to stop at or go up to wherever you want it to!
except a decent boost controller will have an electronic solenoid... that only lets that 7psi get to the wastegate actuator, when you want it to.
