Anyone know the differences between the ST215W and ST246W?
Postby Inane » Mon May 02, 2005 10:37 am
Looking for actual differences in the engines...
the 3S-GTE from the 215W caldina and the 3S-GTE from the 246W caldina
Inane
Postby fivebob » Mon May 02, 2005 10:47 am
Performance specs are the same. AFAIK they are the same engine, and neither one has VVTI-iL, that's only on the NA models.
Postby Inane » Mon May 02, 2005 10:55 am
/me slaps self
of course thats NA only...
so the only thing causing it to qualify as an LEV would be a more restrictive exhaust?
Inane
Postby fivebob » Mon May 02, 2005 11:00 am
Don't know, but I doubt you'd get the same power if the exhaust was more restrictive, maybe they added another cat???
Postby Mr Revhead » Mon May 02, 2005 12:27 pm
theres a few different parts.....
ecu is different
crank (rods the same)
pistons
inlet manifold
injectors
fuel rail
cams and head are the same, downpipe/cat supercedes to same item... looks as though 246 could have another cat, hard to tell, it it does its part of the main exhaust...
the above parts are differnt part numbers..... some only one digit out, others liek the injectors are a totally different number.....
its possible that due to the newness of the 246 soem supersessions havnt been loaded, maybe the 215 parts are still in stock and they wont change the numbers untill they are exhausted... but thats pure speculation on my part...
if theres any other parts you want me too look at just sing out
Postby Mr Revhead » Tue May 03, 2005 11:01 am
iv been thinking... does it qualify as an LEV cause it meets certain regs in japan? what does a vehicle in NZ need to be classed as an LEV?
