help: removing 4agze pulley
Postby Ae86drift » Mon May 02, 2005 10:21 pm
Tried huge power bar with extension bar and 3 types of rattle gun to remove it... 8O
Any tips or tricks to locking the pulley while rattling the bolt or just any advice would be appreciated..
chur
--++ SlAp SecoNd ++--
Ae86drift
Postby Rick » Mon May 02, 2005 10:24 pm
You are trying to take the crank pulley off right? is it out of a vehicle?? on an engine stand??
Postby cr1mnl » Mon May 02, 2005 10:35 pm
to take mine off i braced to power bar against something solid under the car and cranked the engine to losen it.
www.ology.co.nz
cr1mnl
Postby sopachrga » Mon May 02, 2005 10:37 pm
Have you tried wedging a power bar on the ground, and flicking the starter motor for a second?
If you need an explaination of what to do just ask.
If you do try it make sure you take the cable of the coil, so the car can't start.
[EDIT]Ooops, took too long to type that :oops: [/EDIT]
1987 S/C Manual AW11 (SOLD)
I don't have a Toyota anymore~!
sopachrga
Postby Lloyd » Mon May 02, 2005 10:37 pm
Yeah, bracing and a quick crank is about the best way if you cant get it moving at all
Then your next mission is getting the pulley itself off :lol:
Postby sopachrga » Mon May 02, 2005 10:40 pm
If all else fails you can take the end plate off the gearbox bellhouse, and wedge a screw driver in the fly wheel ring gear.
Not the best idea but it can work.
sopachrga
Postby Rick » Mon May 02, 2005 10:42 pm
when my engine was out of the car I made up a plate which bolts onto where the flywheel sits and rested it on the engine stand, worked a treat.
Postby matt dunn » Tue May 03, 2005 12:37 am
To remove mine I do this,
Put the car in gear and get someone to hold their foot on the brake. This stops the engine from turning so you can undo the nut.
I am no a fan of the power bar and starter motor method.
Matt
