AE111 making high pitched noise after start up
Postby gary_l » Tue May 03, 2005 3:21 pm
Hi guys. I've been hearing this high pithced noise coming from the engine after start up. Can't describe exactly how the noise is like but it's high pitched, squeaky and sounds like something's turning. It goes away after i've driven around for a while.
what in the world might be causing that irritating noise? Any idea?
gary_l
Postby ATAl » Tue May 03, 2005 3:36 pm
It's possibly an accessory belt slipping, check the tension on the belts to the alternator, power steering and ac.
Push on them and they shouldn't deflect any more than 1cm, if its more than that you'll need to adjust them.
ATAl
Postby CozmoNz » Tue May 03, 2005 5:48 pm
$25 on sqeeky alt belt.
thats excactly what it was in the sw20.
Rayne For President!
CozmoNz
Postby pervert » Tue May 03, 2005 5:52 pm
$25???
What an odd amount Cozmo...
Need to buy a tinny or something?
:lol:
pervert
Postby blackmk3 » Tue May 03, 2005 7:34 pm
mite b the air conditioning pump if its turned on...the bearings will warm up after a while and quiet down
Mk3 MA70 Supra
blackmk3
Postby Xavier » Tue May 03, 2005 10:16 pm
could be ur cam belt... when was it last done???
Cheers...
My Profile
1999 Altezza AS200 Z
1995 Trueno BZG (Previous)
1992 MR2 GTS (Previous)
Xavier
Postby Dell'Orto » Tue May 03, 2005 10:23 pm
pervert wrote:$25???
:lol:
Sucks to be south island paying $25 for a tinny :lol:
Without hearing it, its pretty hard to make an educated guess...hell, could even be a clutch bearing
Re: AE111 making high pitched noise after start up
Postby CozmoNz » Wed May 04, 2005 11:41 am
gary_l wrote:Hi guys. I've been hearing this high pithced noise coming from the engine after start up. Can't describe exactly how the noise is like but it's high pitched, squeaky and sounds like something's turning. It goes away after i've driven around for a while.
starter motor takes current
driving means revs go up....
revs go up means alt charges...
current is replaced... WHAMO alt stops / slows charging. noise goes away.
its the bloody alt belt >.> if its not, cozmo dosnt get his tinny, k?
CozmoNz
Postby gary_l » Wed May 04, 2005 7:33 pm
thanks guys for the input.
xavier, my cam belt was done not too long ago. should not be it. thanks though.
cozmonz and atai, i guess wat u guys said made sense. thanks!
will get it checked out.
gary_l
Postby Alex B » Wed May 04, 2005 7:41 pm
could be bearings. They caused my belt to go compleatly mental as in the "V's" of the belt accualy got smaler as it went across hard to explane.....made a very irratating noise tho took ages to fix as couldnt figure it out.
Postby Xavier » Wed May 04, 2005 9:22 pm
gary_l wrote:xavier, my cam belt was done not too long ago. should not be it. thanks though.
maybe u need to tighten it, go back to ur mechanic that change ur cam belt... my previous car has the same problem after changin new cam belt and fan belt... they tighten it and it went silent... he told me the belt needs to get season in... they shouldn't charge u for tighten it since u done ur cam belt there... hope this helps... :D
Cheers...
My Profile
Xavier
Postby Alex B » Wed May 04, 2005 9:44 pm
v belts do not need to be increadbly tight. if your cam belt i loose well you may have bigger issues than a noise.
