New Tires - Opinons pls
Postby Si » Tue May 03, 2005 11:42 pm
After some new tires for the supra beast,
225/50r16 for the front to be exact,
What are peoples thoughs on suitable tires? i dont have a problem paying ~$250 each if they are going to perform well and be suited to a 'aggresive' 'spirited' driving style.....
At this stage im kinda deciding between the Toyo T1S like i have atm, or possibly something of the dunlop sort. The toyos are approx 190each, the dunlops depending on the model $230-250.
Anyone had any experience with any off these or could reccomend any others to look into?
Thx
Si
Current: , '96 SubaruImpreza
Si
Postby Truenotch » Tue May 03, 2005 11:46 pm
reckon toyo's
Truenotch
Postby pidge » Tue May 03, 2005 11:47 pm
Have a gander at the Toyo T1-R - very similar to the T1-S, but it has more rigid shoulder blocks. At least my Levin is definitely steering better on the T1-R 205/50R15 I have a the front than it did on T1-S 195/55R15 - some what less plow under steer on the Rosebank round about each morning on the way to work than before (more like goes around on rails now ;) ) The T1-R's were a bit more that the T1-S ($5 or $10 per tire more)
pidge
Postby Si » Wed May 04, 2005 12:12 am
Ah just done some more searching, the t1-r is the replacement for the t1-s, info can be found on toyos au website not the dotcom.
The New Proxes T1-R is Toyo's new ultra-high performance passenger car tyre, superseding the Proxes T1-S. The Proxes T1-R utilises a newly developed silica tread compound with a ultra-high molecular polymer that provides improved grip levels on wet & dry roads and improved wear resistance. The directional tread pattern of the Proxes T1-R maintains the exceptional resistance to aquaplaning of the Proxes T1-S, combined with a new rib / block tread shoulder arrangement that improves dry cornering grip, improves resistance to irregular wear and reduces tread noise.
Apparntly they have not superseded the T1-S in NZ yet...
Si
Postby SIDE_FX » Wed May 04, 2005 1:39 pm
dunlop dz101's havent tried them but i had 901's and a mate said that they some how managed to make thewm better and 901's pulled me out of some $&#$% hairy hairpins
SIDE_FX
Postby drizzt_stylez » Wed May 04, 2005 2:41 pm
I've heard great things about the Goodyear Eagle F1 GS-D3 - found some good survey results on them somewhere I'll try and dig up for you.
Heres a link to specs etc in the meantime:
http://www.goodyear.co.nz/tyres.asp?id=2
I think it also has some news articles on that page for awards etc - I'm gonna get these when I get my new wheels. :)
edit - Here is the link to the tyre survey I was talking about:
http://www.tirerack.com/tires/surveyresults/surveydisplay.jsp?type=MP&
drizzt_stylez
Postby TrouserFxGt » Wed May 04, 2005 3:02 pm
I have dz-101 direzzas on my car and they are marvelous. Wicked grip in the wet and quite quiet.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby Distrb » Wed May 04, 2005 3:13 pm
drizzt_stylez wrote:I've heard great things about the Goodyear Eagle F1 GS-D3 - found some good survey results on them somewhere I'll try and dig up for you.
i'll vouch for them being a damn good road tyre.. but i wouldnt put them within earshot of a circuit if you want them to last any decent length of time...
i'll put my faith in Khumo Escta Supra 712's have had them on my cars for a number of years. Good balance between grip and wear when used in spirit ;).
Distrb
Regular Poster
Postby JT » Wed May 04, 2005 4:40 pm
TrouserFxGt wrote:I have dz-101 direzzas on my car and they are marvelous. Wicked grip in the wet and quite quiet.
Just got a set of these all round and I agree.
Noticeable improvement from the 901.
JT
Postby BigDon » Wed May 04, 2005 7:25 pm
I have just put 2 Goodyear Eagle F1 GSD 3's (205/40/17) on the front of my 20V FX and moved some Dunlop FM901's to the rear.
The 901 were fantastic, but have worn quickly. I was told the diretezza's are not as good as the Goodyears by a few people, so I went for the Goodyears. The Goodyears seem to grip better and the car seems to brake better but I am yet to give them a good thrashing to see how they go when they are really hot.
Price wise goodyears were $220 each fitted and balanced at Tony's in Wellington and they wanted $180 each for the Dunlops.
BigDon
Postby Bazda » Wed May 04, 2005 7:35 pm
for price/wear/grip I would go the gt radial :D
I got them on my car and they seem to hang on pretty good, even with my acceleration they dont spin anywear like when I had Khumo 711's, as for toyo t1's they were absolute crap on my car, I could just keep on spinning through the gears with those tyres!!
Postby sergei » Wed May 04, 2005 8:10 pm
GoodYear F1 GS-D3... very good on dry and superb on wet
Users browsing this forum: Google [Bot] and 20 guests
