tapet noise on a 20 vavle?
Postby vteckiller » Wed May 04, 2005 12:18 am
umm i gt a levin bzg black top 20v i think its the tapets that are making noise not sure, its a chuging sound its quiet anoying as it sounds like a diesel, anytips how to fix it and wher to get it fixd and a ruff price? also tried that mb40 and lifter free crap, it didnt work :lol: cher cher
vteckiller
Postby Mr. Mainstream » Wed May 04, 2005 12:23 am
check the oil bro 99% of the time it is, im assuming 20v 4age is hydrolic lifters
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby RedMist » Wed May 04, 2005 7:44 am
Its quite often the VVT pulley. Possibly an injector, or valve clearances.
Hydrolic lifters? Its cam on bucket.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
Postby CozmoNz » Wed May 04, 2005 11:35 am
be the vvt pully >.>
justs get noisyer, when you win lotto, replace it.
Rayne For President!
CozmoNz
Postby Mr Revhead » Wed May 04, 2005 12:50 pm
they arent that badly priced....
anyway:
http://forums.toyspeed.org.nz/viewtopic.php?t=30098
Postby Rob » Wed May 04, 2005 8:03 pm
Try changing oil first. I've seen a couple 20v crap out from scummy old oil.
Use an engine flush first
1990 ST185H - project
1996 VS Acclaim wagon
Rob
tapet noise
Postby vteckiller » Thu May 05, 2005 10:53 pm
i put in some mobil syn 5-50w 70bux! but that wasnt a full oil change but it didnt make much different, so i would need the clearance set right?wots the vvt pully? :) and redmist wot u mean by its cam on bucket?
vteckiller
Postby offensive » Thu May 05, 2005 11:44 pm
he means it has no hydrolic lifters, dont worry about it. If i had a pic of a 20v engine i could show u where the vvt pully is. It'll get loud but it shouldnt be a big problem, just noisy. By the sounds of it too, ur prolly not mechanically minded, so go see a decent mechanic to get it changed.
above this is a line
quote: "Reclusive girls dont shave their pubes"
offensive
Re: tapet noise
Postby matt dunn » Fri May 06, 2005 12:58 am
vteckiller wrote:i put in some mobil syn 5-50w 70bux! but that wasnt a full oil change but it didnt make much different, so i would need the clearance set right?wots the vvt pully? :) and redmist wot u mean by its cam on bucket?
20V's dont normally need the tappets reset. Ever. unless you modify something like cams etc.
Matt
Postby 10k 20v » Sat May 07, 2005 4:37 pm
ur dead right there matt
there is a test u can do to check the vvt pulley noise, its been posted before
earth out the pink wire with the black strip.
if noise quitens or goes away then its your vvt pulley.
the connector is located above the exhaust on the r/hand side of the motor (your left hand when your standing at the front looking towards the windscreen).
10k 20v
Postby spencer » Mon May 09, 2005 11:08 am
also on a Blacktop I had the cam belt tensioner crapped its self and caused the belt to become very slack and make a tapping noise. Something to check if the VVT pulleys ok
ms63 crown
spencer
Postby Mr Revhead » Mon May 09, 2005 11:26 am
yes the tensioners on those do fail, if doing the cambelt ALWAYS do the tensioner on the black top. ALWAYS
Postby aesc » Mon May 09, 2005 11:34 am
Could a cam belt tensioner make a knocking/tapping noise as well if its buggered?
EX AE101 owner
2013 Ford Focus ST
aesc
