ae111 non superstrut springs fit ae111 superstrut??
Postby phatman3801 » Thu May 05, 2005 10:50 pm
i have some jamex springs in a ae111 levin non superstrut, will these fir into a ae111 with superstrut???
phatman3801
Postby sergei » Thu May 05, 2005 11:44 pm
I don't know for sure if it works for 111 but with 101 SS and non-SS springs are exactly the same....
Postby phatman3801 » Fri May 06, 2005 9:36 am
o ok kool, can ne 1 verify that ae111 ss and non ss springs are the same or can be interchanged?
phatman3801
Postby Mr Revhead » Sat May 07, 2005 12:57 pm
the rears can be swapped, but i think youll find the fronts on the s/s are shorter.....
Postby 10k 20v » Sat May 07, 2005 4:26 pm
i ran into trouble using non superstrut springs in my trueno wn it was s/s
the front stayed the same height and he rear shot way the hell up.
it turned out the platform height on the rear shocks are different 8O
so in my experiance no, they will fit but the heights end up all over the show.
10k 20v
Postby Mr Revhead » Sat May 07, 2005 5:04 pm
are you sure? not the other way around?
TRD list the same shocks for the rear for s/s and non s/s, and they can be used with the stock springs. they also list the same springs for the rear, and they can be used with stock shocks..... however they list the springs being unique to s/s cars.....
Postby 10k 20v » Sat May 07, 2005 7:11 pm
yeh i'm sure
couldn't really explain why so pedders just had some custom coil springs made for the whole thing. then it was mint.
10k 20v
Postby Mr Revhead » Sat May 07, 2005 7:15 pm
well. that is weird :?
maybe if some one has some struts lying around they could take some measurements of the platform height.
ill be replacing my rears soon so will do that then.......
Postby 10k 20v » Sat May 07, 2005 8:47 pm
i shall do the same on mon
10k 20v
Postby TRDWGN » Sun May 08, 2005 9:37 am
Back in the days of my AE101 SS i bought some Kings (lows not superlows) from a guy who had them in a non SS, fitted sweet, ride height changed roughly half an inch down in the front and raised the rearhalf an inch from the standdard springs, net effect was indifferent height but a far superior ride, having said that once i put some 17 x 7's on there they nicely filled out the wheel wells, I assumed at the time the SS springs must be (factory) lower then non SS as these King springs should have pulled it down around 35mm and effectively didn't lower it any further...
TRDWGN
Postby sergei » Sun May 08, 2005 10:17 am
funny thing is I have SS springs on my non-SS on front and rear, the car is lower apporx 25 mm (front and rear). They are TRUST branded lowering springs for SS. plus I have laying arround front stock SS springs and non SS and they look exactly the same and height is exactly the same...
thats 101 springs.
