strange noise from 4A-GE bluetop
Postby RickGT » Thu May 05, 2005 11:10 pm
i have an 84 fx-gt and ever since i got it it has been makin a few weird noises, but its got louder, its really loud when its cold but when it warms up its not as noisy but still noisy enough to annoy me, it seems to be comming from the left hand side, its not the waterpump, my mate said it could be the a/c pump, (all a/c hoses have been stripped, just bare pump) any help would be great :lol:
MX73 GLXi Cressida 1JZ-GTE
EP91 Glanza V
RickGT
Noise
Postby GOLDAE86 » Thu May 05, 2005 11:19 pm
Take the A/C belt off and start the engine, if the noise is still there, remove the Alt belt, if noise is still there, take it to a workshop for them to have a listen :D
To finish first, first you must finish
GOLDAE86
Real Life Mechanic
Postby RickGT » Thu May 05, 2005 11:22 pm
kool thanks, wouldnt running it without the alternator reck it, cause it is also the waterpump?
EP91 Glanza V
RickGT
Postby Alex B » Thu May 05, 2005 11:25 pm
if its on same as waterpump (must be diffrent from 4A-F :? ) just take it off to test if that belt is the cause. Could be bearings in altinator etc too. Just take one belt off at a time to see if the noise goes away. WHen you find which belt is causing it look deeper into the accessories on the belt. Also try giving the belt a good wirebrushing.
Postby RickGT » Thu May 05, 2005 11:30 pm
yea ill do that thanks! i know its not the belts they have been replaced, its more of a clinking sound
EP91 Glanza V
RickGT
Postby RickGT » Thu May 05, 2005 11:36 pm
also, any help on exhaust setups on my fx-gt would be great, i was thinking 2.25" pipe with a super large coby, then a stainless tip which is same size and stlye as a coby but just stainless??? any good?
would removing the cat be any help, im afraid that its going to be to loud, thats y i was thinking of leaving the cat in there.
EP91 Glanza V
RickGT
Postby THA SHZ » Fri May 06, 2005 9:15 am
leave the cat in and u may find tht ul need a resonator aswell to cut dwn the noise , mine was quite loud and it took 2 cobys and a resonator to shut it up :?
THA SHZ
Postby JT » Fri May 06, 2005 12:46 pm
Mine makes bit of a rattle when cold, sounds tinny, not like a bearing but one day I'll get round to finding it.
I've got a 2" with 2 large reso's and a straight through muffler. Sounded like a fartbox honda with only one res in so put the second one in and it has just the right amount of growl.
JT
noise
Postby JasonZE » Fri May 06, 2005 10:46 pm
Double check the bottom crank pulley bolt is tight and the pulley is not broken. (I have seen a few with loose pulleys)
Otherwise good advise above remove belts to eliminate noise and diagnose the problem.
And if noise still there with no belts go to mechanic as it could be a faulty cambelt tensioner 8O
JasonZE
Real Life Mechanic
Postby RickGT » Sun May 08, 2005 10:05 pm
i have checked alternator and waterpump and a/c pump, none of these are making exsesive noises, ive come to the conclusion that it could be the dizzy, as the Orings are stuffd cause it leaks oil, could this be ratling around making the noise, because it seems to be comming from around there
EP91 Glanza V
RickGT
Postby Alex B » Sun May 08, 2005 10:10 pm
how did you check them?
Postby RickGT » Mon May 09, 2005 10:58 pm
i took off the belts and started it up, but noise was still there
EP91 Glanza V
RickGT
