winding noise from my diff or geabox
Postby Babz » Sun May 08, 2005 1:42 am
i have a 1982 toyota carina gt-turbo and when im travelling i can hear a winding kinda noise from my diff or geabox or wheelbearing but i have checked my oil in the diff and my wheel bearing seems to be ok, anyone any idea?? it also makes that noise when im rolling in neutral
Babz
Postby Lloyd » Sun May 08, 2005 7:12 pm
Does it make the noise when you're rolling with the engine off?
Does it make it when you aren't moving but with the engine on?
Postby Babz » Sun May 08, 2005 8:34 pm
nope it doesnt make that noise when im rolling wid my engine off and also doesnt make that noise when when my car is idling. Only when im driving or rolling in neutral with my engine on?? Usualy at speeds over 70k's
Babz
Postby Chrislost » Mon May 09, 2005 7:16 pm
well if engine is on and the cars in neutral then dunno
if the engine is off and gears in neutral and noise happens then could be dif or gbox...
Chrislost
Postby u4dina » Mon May 09, 2005 9:51 pm
have u just noticed it..??
u can get this from low profile tyres... i get it a bit from my 35 series..and i know when my freind put 40 series on his altezza it made the same noise.......just an idea anyways....
1998 5spd Gt-T Caldina loving it...........
u4dina
Postby Lloyd » Mon May 09, 2005 9:58 pm
But if you roll along with the car off and there is no noise then it cant be tyres.
If its only there when the engine is on then its going to have to be something inside the gearbox/diff. As to what it is.... I cant help you.
The fact that it doesn't make a noise when idling is annoying, that could point to it being an input shaft bearing on the gearbox or something along those lines.
Being that it makes the noise when moving in neutral, but not when sitting there idling in neutral doesn't seem to make a lot of sense. From that you would have to assuming the diff but then it should be making it while you're rolling with the engine off :?
Get a new gearbox and see if it goes away :D
Postby thaphatty » Mon May 09, 2005 10:35 pm
checked your gearbox oil as well? could be a mainshaft bearing perhaps, not likely though.
take it to a mechanic who can see it, will make diagnosis easier and alot more accurate.
thaphatty
Postby Babz » Mon May 09, 2005 10:40 pm
Thanx alot poeple, will check the gearbox oil and go from thea :lol:
Babz
Postby KinLoud » Mon Jan 31, 2011 11:27 pm
does it make the noise in all gears or is it quieter in 4th? = bearing in gearbox maybe layshaft bearing
Postby siren676 » Tue Feb 01, 2011 12:12 am
dude this thread is 6 years old
siren676
Postby h8wrxs » Tue Feb 01, 2011 2:02 am
lol resurrecting old threads
i like reading the old ones
h8wrxs
Postby KinLoud » Wed Feb 02, 2011 8:07 am
Doh! LOL - too much thread trolling!
Stuck in 2005 - reliving the past! Feels like Groundhog Day!
Users browsing this forum: Bing [Bot] and 6 guests
