AE111 Suspension
AE111 Suspension
Postby allmotor111 » Tue May 10, 2005 6:47 pm
Hey team,
Just a quick question about suspension. Will the super strut shocks and springs from a AE101 fit in a superstrut model AE111?
Basically are they the same?
Cheers, Ben.
allmotor111
Postby Mr Revhead » Tue May 10, 2005 7:13 pm
yes i beleive they will
Postby bad20v » Tue May 10, 2005 7:26 pm
Mr Revhead wrote:yes i beleive they will
I agree. But I think that Toyota has upgraded the bushings they use in the ae111 s/strut joints to a longer lasting compound for better reliability. That's due to alot of the joints in the ae101 models flogging out. God knows that I've rebuilt enough of them.
Thank-You.
bad20v
Postby Mr Revhead » Tue May 10, 2005 7:31 pm
the actuall s/s arms are different though..... havent measured any to see if the arms are swappable.....
Postby 10k 20v » Tue May 10, 2005 11:04 pm
there different in the sense that on the ae111 the ball joint on the arms are tappered instead of straight with a locating bolt. so i guess if you changed the flange plate that bolts onto the bottm of the hub you would then be able to swap between models.
10k 20v
Users browsing this forum: Bing [Bot] and 21 guests
