by ATAl » Wed May 11, 2005 8:30 am
I can only give you a general idea as I have never seen the engine of one of those.
I'm guessing its carburated which helps a bit.
You want to find the distributor - its the bit with the 4 or possibly 5 big wires going into it at the top and to the side of the engine. (sorry if this is to simple I have no idea how much you already know about engines).
Put a mark where the distributor attaches to the engine so you can reset it to the default place if need be.
It should be held on to the engine by 2-3 large bolts, loosen (not remove) these and turn the whole distributor towards the firewall a tiny bit - 1-2 mm (also guessing here, it could be towards the front but most likely towards the firewall).
Now retighten the bolts and see if it runs, if it starts making a sound like stones in a tin can you need to turn the distributor the other way.
