HELP: WIRING FOR HKS TURBO TIMER !
Postby LEV_101 » Fri May 13, 2005 5:43 pm
hi there.
i just brought a hks turbo timer and i dont know which wire goes to where. would be great if someone can help me as i am LOST ! its for my levin if that helps. the turbo timer has blue - acc, black earth, grey-hardbrake, green - IG1, yellow IG2, red - 12V.
i have no idea where the blue - acc , green - IG1 and yellow IG2 goes to ... PLEASE HELP ME :(
LEV_101
Postby Stealer Of Souls » Mon May 16, 2005 10:08 am
Easiest place to get the wires is probably the ignition barrel.
Acc -> Accessory wire. Will have 12V when key is in "acc" or "on" position.
IG1 -> Ignition #1. Will have 12V when key is in "on" position.
IG2 -> Ignition #2. Will have 12V when key is in "on" poition.
Toyotas are a little funny. A lot (if not all) of them have two iginition wires. One runs all the dash/instruments, the other is the actual ignition system. I think the IG1 should be on the wire that runs all the ignition system.
'86 AE85.5 Levin
Stealer Of Souls
