Shims WHAT ?*&?!& *pics*
Postby MR2boy » Sat May 14, 2005 8:29 pm
Ok can anyone who has taken a silvertop 4age head off tell me what these 3 things
are and how many of the washers there are supposed to be?
I've got 10 washers I asume they are to keep the shims? in place for when vvt
kicks in? If thats true am I supposed to have 12? Does it matter if I use normal washers
for the two I am possible missing?
**** Car here ***
MR2boy
Postby ChaosAD » Sat May 14, 2005 8:36 pm
There are 10 head studs which should have washers under them
ChaosAD
Postby andyztouring » Sat May 14, 2005 8:53 pm
The washer for the head bolts, cups are for the shims which go over the valves
andyztouring
Postby MR2boy » Sat May 14, 2005 9:38 pm
ok thanks guys
**** Car here ***
MR2boy
Postby RedMist » Sat May 14, 2005 10:35 pm
I truly hope you have numbered those shims so that you know which bucket to locate to which valve. Otherwise you'll have to measure clearances and reshim every bucket.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
