by AE85coupe » Tue May 17, 2005 12:26 am
it cost a fair whack man, and parts aren't as easy to find anymore
looking at about $2500 at least all up if you want it to be good (depending on what setup you want) and thats doing the labour yourself, unless you know what your doing and have some cheap part hookups, it will cost you an arm and a leg
use carbies or make friends with an auto electrician, cause the wiring cost will kick your arse (especially if its a fwd loom)
there is no such thing as a cheap easy AE85 to 4age t50 etc. efi conversion, unless you have a nice donor AE86 or RWD 4age Carina etc. which are dam rare anyway
