4agze turboing and tacho questions
Postby fat-boy » Mon May 16, 2005 11:40 pm
got a 4agze and i cant find the tacho signil wire to run to my tacho.
any help would be great.
also im lookin at puttin turbo onto thos motor
4ag-ze-te :D sounds gud to me
ive been told teh ze comp is suficint enuff but is recomendable to go link plus ecu.
im jsut lookin at runnin ct20 turbo and a frount mount
so it goes from the pod to the tubro then i/c then superchager then manifold.
wat sorta problem would i run into and wat sort for power would i gain from this ?
cheerz
tony
"F T 50"
fat-boy
Postby neon_spork » Tue May 17, 2005 12:53 am
All sorts of problems :) you probably want to ditch the supercharger and just run the turbo, im sure eveyone will tell you that trying to run both the SC and the turbo is much more trouble than its worth.
Try a search for 4agte and stuff, there is quite a lot of info on here regarding this conversion.
neon_spork
Postby evil_si » Tue May 17, 2005 8:27 am
i think you will need a tacho interface, connects to the coil wiring and gives you a tach output,
there was one on trade me,
as for turbo, get a manifold made, intake modified to suit rwd, the standard computer is good for 14psi,
a ct20 might be a bit small?
ive done a few ze turbo conversions, and they go damn well.
evil_si
Postby Silent Knight » Tue May 17, 2005 11:56 am
evil_si wrote:i think you will need a tacho interface, connects to the coil wiring and gives you a tach output
Also a dictionary and some english grammar classes would help him out alot. :lol:
Last edited by Silent Knight on Tue May 17, 2005 12:27 pm, edited 1 time in total.
Silent Knight
Postby Distrb » Tue May 17, 2005 12:06 pm
Also a dictionary and some english grammer classes would help him out allot.
grammar, alot :wink:
Distrb
Regular Poster
Postby Bazda » Tue May 17, 2005 12:24 pm
what model 4agze are u running? the boost level u can run with standard ecu's depends on which model you have.
Postby fat-boy » Tue May 17, 2005 9:39 pm
umm i wouldnt have a clue wat model as i jsut got the car
its a 4agze 16valve
runnin a map sensor.
was told comp starts leaning out about 14.7psi
i want a turbo super charged engine
so i get both low dwn boost rite upto the high rpm range.
"F T 50"
fat-boy
Postby Lloyd » Tue May 17, 2005 10:20 pm
Bugger the standard ECU if you're going twincharged. I've looked quite seriously at the option but it is a lot of money and fabrication work. Personally I wouldn't want to feed one charger into the other as it complicates things a fair bit more. You'll also need something to control the superchargers clutch which the standard ECu does quite well, not too sure how aftermarket ECUs go with that.
My advice would be just to go turbo, they go bloody well for what they are.
Postby evil_si » Tue May 17, 2005 10:24 pm
if its map sensed it will have a boost cut at 14.7, a lot different to leaning out,
hks did a twin charge kit, when it was retailed in nz it was around the 10k mark 8O , i only knew of 1 twin charged 4agze in nz, not even sure if its still round.
but you cant just slap a turbo on and blow thru the s/c as it wont handle it,
evil_si
Postby Bazda » Tue May 17, 2005 10:27 pm
what happened to the guy who was posting up here that he was going to do it and told us we didnt know what we were talking about when we said it was real hard and he said it was easy cos he drew it on paper and said its going to work cos he had some engineering skills or something....then in 2 weeks he said he got it all sorted and started making it and will be done like few weeks.....well its been couple months + now.....
Postby Bazda » Tue May 17, 2005 10:32 pm
Postby evil_si » Tue May 17, 2005 10:34 pm
haha yeah well, even longer than that isnt it?
i know that jono from performance metalworks made up a setup a while back for a 3sgte, not sure what ever happened to it but to my knowledge it was never completed,
if you know jono or have seen his work it will make u think twice about how hard it is to do.
evil_si
Postby Bazda » Tue May 17, 2005 10:41 pm
evil_si wrote:haha yeah well, even longer than that isnt it?
yea i know them, Dan from herbert fabrications now works for him, and Dan's work is prob the best I have seen out of any fabricator I have meet.
Postby fat-boy » Tue May 17, 2005 10:59 pm
well i diddnt think it would be that hard :?
oh well.
guess ill go turbo as the supercharger just aint doin it for me 8)
"F T 50"
fat-boy
Postby evil_si » Tue May 17, 2005 11:15 pm
i havent seen much of dans work, from what ive seen its awesome, and jono's work is just mind blowing
evil_si
