Blacktop 20V injectors specs - who knows em!
Postby TWSTD » Tue May 17, 2005 9:32 pm
OK peoples - what do you know about black top 4age injectors?
Flow (cc) = ?
Impedence = ?
Configuration = Top feed
Replaceable with what in the way of 500cc injectors if you still want to use the factory fuel rail?
Thanks!
Click here!
TWSTD
Postby vvega » Tue May 17, 2005 9:53 pm
there 295's
side feed
and low inpedance
replace with 440's from a sw20 or celica
or 550's from a gen 3?? sw20
or from a us spec 2jz.... ask gadget,,,,
or you can use the rx7 injectors with new orings
v
vvega
Postby EssDub » Tue May 17, 2005 10:52 pm
what kind of gain do you think you could achive by swapping the injectors for those from an SW20?
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby Lloyd » Tue May 17, 2005 10:59 pm
You'd be able to get enough fuel in if you're uping the boost. Same reason I've got 3S-GTE injectors on my Silevrtop head
Postby EssDub » Tue May 17, 2005 11:07 pm
so no use on an NA 20v? :(
EssDub
Postby TWSTD » Tue May 17, 2005 11:18 pm
Awsome - thanks vvega.
Click here!
TWSTD
