Wat engine oil to use
Postby 4-AGE 4-LIFE » Tue May 17, 2005 9:53 pm
I own a ae101 4-age
im using 15w-40 engine oil at the moment
and the engine is very noisy
wat viscosity oil would quitein down those hydrolic lifters
Ben Threadwell
Exsus Automotive
Suspension specialists
4-AGE 4-LIFE
Postby vvega » Tue May 17, 2005 9:57 pm
hahahahahahhhahahhah
no hydrolic lifters mate
its ethier ya vvt pully or somthing very sinister :D
gotta love this sometimes :D
v
vvega
Postby 4-AGE 4-LIFE » Tue May 17, 2005 10:00 pm
nah i can hear the sound of the vvt pully but i can hear other noises
im not to keen on doing the vvt pully yet its pricey
and wat viscousity oil should i use neway
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby Lloyd » Tue May 17, 2005 10:10 pm
Should be fine with 15W40. What are these other noises like?
Postby 4-AGE 4-LIFE » Tue May 17, 2005 10:14 pm
tapping i got a lil bit of belt noise annoys the sh*t outta me
and it wont go away no matter wat tension the 2 belts are
could it be somthing to do with cambelt tensioner
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby phatman3801 » Tue May 17, 2005 11:04 pm
its most likly ur valve clearances, prtty common thing for the 20valves!
phatman3801
Postby EssDub » Tue May 17, 2005 11:11 pm
mine runs perfectly on Castrol Protec 15W40 with no noises at all :)
1992 SW20 MR2 GT-S Turbo
Previous Rides: Mazda 323, Toyota Levin BZ-G, 1992 SW20 MR2, 1994 Gen3 SW20 MR2 T-Bar
EssDub
Postby aesc » Wed May 18, 2005 1:11 pm
What are the condition of your auxillary belts like? I had some pretty nasty noises coming from mine mainly when cold but also when warm to a lesser extent. Ended up being the Supercharger and Alternator belts. Maybe if you can, take one belt off at a time and see if the noise stops, if so then replace the belt(s). Even if they are relatively new could still be the problem, by aux belts were only around 20kms old and the were buggered. 8O
Could possibly be the cambelt tensioner, but try the above first.
Personally id be running 10W40, but 15W40 is ok, shouldn't cause any tapping noises as such unless you havent changed the oil recently
EX AE101 owner
2013 Ford Focus ST
aesc
Postby 4-AGE 4-LIFE » Thu May 19, 2005 3:03 pm
replaced both belts bout 1 000 kms ago
adn im doing an oil change today going to try some 10w 40 in it
see wat comes out eh
if the belt noise is still there tonight at the toyspeed meet hopefully someone wil turn up who could point me in the right direction
Ben Threadwell
Exsus Automotive
4-AGE 4-LIFE
Postby JT » Thu May 19, 2005 5:42 pm
4-AGE 4-LIFE wrote:replaced both belts bout 1 000 kms ago
The oil shouldn't make a noticeable difference. If it was noisey when cold, like aesc encountered, it may make a difference changing the cold property of the oil. If the engine is making annoying noises just turn the stereo up :wink:
BZGEE wrote:mine runs perfectly on Castrol Protec 15W40 with no noises at all :)
In a bz-g you should be using a better quality oil than that. Go for a semi-synthetic and 10W-40.
JT
