by RS13 » Thu May 19, 2005 12:38 am
You could piss around with that, but it seems like a lot of hit and miss, when your engine is at stake, you don't want to rely on a 50c diode.. an engineer friend of mine had a Honda turbo done on a budget, it was easily done, was a couple of years ago now, I'm pretty sure its' still getting round with the same setup.
From memory, there was a one-way valve on the map sensor line, (so it could only sense vacuum, and would shut under boost) A boost-indexed (rising rate) fuel pressure regulator, injectors from a 2L (?) motor, cut and re-welded n/a exhaust manifold, and press-bent steel intercooler piping. Ran a tad rich, but was reliable on low boost. No ecu mods. Last time I saw him, he was talking about getting the factory ecu remapped to get it running decently, but haven't heard since. In fact, I'm gonna ring him tomorrow!
