high stoplights on when parklights on
Postby 2fas4u » Wed May 18, 2005 6:06 pm
Hi all have these two probs
E1-Park lights working with brake lights-how do i fix that?
E4-High stop working with park lights- how do i fix that?
E1 and E4 is the WOF code. any idea what could be wrong? it is a 90 SW20 MR2. how did i know, cos that was one of the item i failed on in my recent WOF check. could it be the relay or just a fuse? those colour cubes in the fuse box that have headlights etc written on them, are they relays or they fuses? cheers
2fas4u
Postby fangsport » Wed May 18, 2005 9:17 pm
either a shared earth or they have been wired into the circuit incorrectly.
is it an aftermarket hi-stop light or has the factory one been relaced and the wiring spliced incorrectly?
fangsport
Postby 2fas4u » Wed May 18, 2005 9:34 pm
fangsport wrote:either a shared earth or they have been wired into the circuit incorrectly.
neither, all lights were original. the only electrical mod i have conducted was hooking up the tacho to the negative ignition coil which i have finally found which is next to the diagnostic box (thanks to the person who told me that earlier). no splicing where done as the neg ignition feed has a female spade socket so i just got a male one and plugged it in.
2fas4u
Postby dazzag » Wed May 18, 2005 10:55 pm
defintly sounds like you have a shared earth possibly a short in 2 those circuits..
if they have a clear plastic top with a metal strip inside they are fusable links (fuses) if it just a plasic cube thing thats no see through its a relay
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby 2fas4u » Thu May 19, 2005 10:15 am
excellent. thanks alot. clears up confusions there :D
2fas4u
Postby JRS » Sun May 22, 2005 3:43 am
sounds like someone put a single filiment bulb in your tail light.
meh.....
JRS
Postby NZ_AE86 » Sun May 22, 2005 10:29 am
Either incorrect bulb fitted or bad earth, more likely to be incorrect bulb though. 8)
NZ_AE86
