ke25 ignition?
ke25 ignition?
Postby 70ke25 » Wed May 18, 2005 8:44 pm
i need a ignition barrel were should i get one fron iv tried repco but the keep suplying the wrong one.
if you can drink and drift your nuts
70ke25
Postby Spannergal » Wed May 18, 2005 9:17 pm
Toyota should be able to give you the right part number and a price. Either email Mr REvhead [on these forums] or go into your local toyota with the details from the Toyota identity plate - frame number etc.
Only thing is that the ignition barrel may be 3 weeks from Japan on order if you want it :(
or you could contact a wrecker in your area
Spannergal
Postby 70ke25 » Thu May 19, 2005 8:44 pm
cheers dude
70ke25
