4k - backfiring HELP
Postby 1goodidea » Thu May 19, 2005 2:05 pm
Well it's more of a constand pop pop pop pop pop whenever your not accelerating except for at idle.
Not just when you decelerating say when comming up to a giveway but even changing up/down gears.
What could it be? I have gaped plugs,and points got new rotor and dizzy cap, adjusted timing, set idle, adjusted air/fuel mixture as best i can all seems fine.
any ideas?
Standard exhaust
1goodidea
Postby pervert » Thu May 19, 2005 2:06 pm
An exhaust leak could cause that...
pervert
Postby 1goodidea » Thu May 19, 2005 2:11 pm
oh k, it has a leak but i can't see how it could affect it.
It's right at the end of the rear muffler where the muffler meets the exit pipe! it's been like that for about 5 months tho, not prior problems
1goodidea
Postby pervert » Thu May 19, 2005 2:32 pm
Hmmm, I doubt a leak there would cause it, it would usually have to be a lot further up around the flange/flexi sort of area.
Mine makes the same noise when not accelerating, but thats because of the exhaust on it, it didn't use to do it with the standard system.
pervert
Postby LEV_101 » Fri May 20, 2005 12:28 am
could your spark plug leads be a problem. how old are they?
LEV_101
Postby 1goodidea » Fri May 20, 2005 9:05 am
yeh they are pretty old, going to replace them next.
I don't think they are the problem though as it seems to be getting perfect spark
1goodidea
Postby scope » Mon May 23, 2005 11:46 am
when my ke30 had a 3k in it it did this backfiring and even the 4k does it. as pervert said it might be cause of non-standard exhausts though?
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby TygerTung » Mon May 23, 2005 11:50 am
It's all part of K series syndrome
TygerTung
Postby pervert » Mon May 23, 2005 11:51 am
Yeah, when I had the standard exhaust (with a hole in the mid section) it made the same noises, then when I went to a free flow with extractors it got even worse, but it now sounds pretty cool, rather than tinny.
When I put the new carb on it quietened it down heaps.
pervert
Postby Muzzie » Mon May 23, 2005 12:04 pm
Exhaust probably.
I have a straight pipe off the manifold of mine and it backfires and burps flames all day long, never did with the original.
Muzzie
Regular Poster
