1g gteu
1g gteu
Postby Zero_Cool » Thu May 19, 2005 10:10 pm
Hi i just bought a ma70 supra manual :D with a 1g gteu
im just wondering what have people done to this engine and what are some mods i could do?
City -> Corolla -> Integra -> Celica -> Impreza -> ?
Zero_Cool
Postby Twolitre » Fri May 20, 2005 12:42 am
You mean a GA70?
With an exhaust and boost contoller around 13psi you should be able to achieve between 150-160 rwKw but after that things start getting expensive as you're talking better intercooler, ECU single turbo etc.
Twolitre
Postby Silent Knight » Sat May 21, 2005 4:26 pm
Sell the 1G and buy a 1JZ.
1G is a POS to start with and does not have much potential. Costs a hell of allot more to mod it aswell compared to a 1J to get the same sort of power figures.
1JZ to start with is a good strong motor and not very expensive to do a little modding here and there to get more horsies.
If your MKIII is an 89+ the 1JZ should bolt straight in as it has the round xmembers compared to the pre 89ers wich had the square xmembers.
Silent Knight
Postby deaf_rattle » Sat May 21, 2005 7:02 pm
Silent Knight wrote:Sell the 1G and buy a 1JZ.
that sounds like personal opinion to me rather than fact.
I think both engines are expensive to mod, once you have done all the straight forward mods (i/c, exhaust, intake, boost)
1ggte still has plenty of potential, and are just as reliable as the 1jz.
Depending on your budget, you may be better to stick with the 1ggte.
But mk3 supras are bloody heavy so id go 1uzfe. (but thats my opinion)
Postby Silent Knight » Sat May 21, 2005 7:04 pm
I have owned and played with both of those motors so I'm talking out of personal experience. :wink:
Silent Knight
Postby deaf_rattle » Sat May 21, 2005 7:08 pm
so you have done them both up and found out their maximum potential?
Not wanting to start an arguement, but i think 1ggtes are very under rated, and have a lot to offer.
i could dig up alot of links to high horsepower examples, but i dont have time at the moment.
Postby Silent Knight » Sat May 21, 2005 7:18 pm
No I have not pushed either of them to their fullest potential.
What I am suggesting is that the 1JZ would be a better base to start off with. Put them both next to each other stock to stock you can clearly feel the difference in performance.
I know of 1Gs getting up in the high HP marks but they require alot more work than a 1J would.[/i]
Silent Knight
Postby deaf_rattle » Sat May 21, 2005 7:32 pm
unrelated to horsepower, but still worth mentioning
is a 1jz this smooth?
http://users.bigpond.net.au/justcallmefrank/engine.avi
Postby Twolitre » Sat May 21, 2005 11:31 pm
Silent Knight wrote:I know of 1Gs getting up in the high HP marks but they require alot more work than a 1J would.[/i]
How do you mean more work? There is a stock internalled 1GGTE powered TA22 on Autospeed running 10's with a single turbo, it has the same mods you would need to make a high Hp 1JZ ie. injectors ecu & single turbo.
The 1GGTE is one of the most under-rated Toyota engines ever built! So what if the stock stuff stuck to the side of it wasn't very good.
Twolitre
Postby Stephen » Sun May 22, 2005 7:25 pm
I've got a supra with a 1ggte in it and I'm making 205kw at the wheels and 980nm of tourqe.to get that I'e done custom intake manifold,custom exhaust manifoldto run a ct26,front mount intercooler custom blow off valve bigger injectors,rising rate fuel pressure,walbro fuel pump,link computer.I'm currently fitting a external wastegate due to boost problemsand rebuilding the turbo with a garret compressor wheel hoping for atleast 250kw.I think iwas getting around 140kw before I did these mods,and from what i've found out thats about the limit on the factory turbos.
Stephen
Postby ee904age » Sun May 22, 2005 7:50 pm
Stephen wrote:I've got a supra with a 1ggte in it and I'm making 205kw at the wheels and 980nm of tourqe..
Cough cough... Whats that smell???
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby Stephen » Sun May 22, 2005 8:47 pm
Do you want me to send you a copy of the dyno sheet
Stephen
Postby Erelyes » Sun May 22, 2005 9:04 pm
Isn't torque at the wheels koo-koo depending on gearing, tyre pressure, etc etc?
Pete
JZX100 / Lancaster6
Erelyes
Postby ee904age » Sun May 22, 2005 9:20 pm
I dont think any gearbox in the world would make his car give the same torque as 3x 1UZ's :lol:
90 SW20 N/A - Sold
ee904age
Postby TygerTung » Mon May 23, 2005 2:11 am
Nah thats about right, because the gearbox multiplies torque.
I figure, noone says the 4A-GEU is shit and you can't get any power out of it, well guess what, the 1G-GTEU is just a 4A-GEU with 2 more cylinders, it features the yamaha cylinder head and everything.
Also the RB20(DET) this is a 2L, but people seem to get lots of power out of that, I mean cripes, whats up with that.
TygerTung
