Wear to find 3mm Headgasket for 2JZGE
Postby strx7 » Sun May 22, 2005 11:19 pm
Like it says in the heading, Anyone know whom i can get a 3mm head gasket for a 2JZGE from???? I can source something from the US if need be but surely someone in NZ most have one???
Anyone got any ideas?
Shane
Postby Akane » Mon May 23, 2005 2:07 am
On the other note, 3mm is quite thick and I don't suggest you using such a gasket. If you want such a low compression, maybe you should look into lower compression pistons.
Postby strx7 » Mon May 23, 2005 9:29 am
3mm is what all the guys turboing 2JZGE in the USA are using, along with arp headstuds and they arent having any problems
Postby Akane » Mon May 23, 2005 4:35 pm
Then you probably have to get some in the states, along with some ARP head studs.
Postby Mr Revhead » Mon May 23, 2005 6:31 pm
ARP studs are readily avail here in nz
