Urgent: What size oil feed???
Postby IH8TEC » Tue May 24, 2005 9:24 pm
hey was jsut wonderign what size oil line i should use for my t3 turbo.
i heard something about a 3mm restrictor on some t3's does that depent on what car it is off?
please someone who has a t3 on there 4agte let me know asap
thankyou
brendon
Postby craigt » Tue May 24, 2005 10:11 pm
Yep 3mm restrictor will be perfect.
If it doesn't fit, force it.
If it breaks it needed replacing anyway!
AE101 4AGZE
KP60 4AGTE project
craigt
Postby IH8TEC » Tue May 24, 2005 10:36 pm
so is that run a bigger line, then restrict it to 3mm just before the turbo, to increase presure, or just a 3mm line?
Postby Lloyd » Tue May 24, 2005 10:42 pm
3mm will be heaps. Got mine at 2 as a restricter, cant remember what size line but it was a fair bit bigger than that
Postby craigt » Tue May 24, 2005 10:52 pm
Ive seen the restrictor at the turbo and in the fitting on the block.
Personally I'd put it as close to the turbo as possible
AE101 4AGZE
KP60 4AGTE project
craigt
