Clutch Problem on AE101 Levin
Postby Flyntoy » Wed Jun 01, 2005 11:04 am
Ever since Ive had my levin the clutch has only engaged when the pedal is nearly let right off, it has been like this for 70,000km, the clutch does not slip at all even going up hills in 5th gear and dropping the clutch it doesnt slip, is there anyway to adjust this so the clutch engages earlier?
Flyntoy
Postby Silent Knight » Wed Jun 01, 2005 11:25 am
The clutch shouldn't have to be pushed right to the back to engage to start with.
Check your fluid levels and also check wether your Slave cylinder is still functioning properly. Give the lines a gud flush and pop some new fluid in there aswell.
What sort of a clutch is it? OE or AM?
Silent Knight
