Zak wrote:If you must go RWD though, use an older IRS celica rear end, it should hold all the power you'll need.
RS13 wrote:As I said in a previous post, doing it to a 4WD car is nowhere near as hard as a FWD, most obviously because of the rear-end setup and transmission tunnel.
Volodkovich wrote:Whats the problem with the front suspension? Just split the Cv in half, and run the stub axle alone. This means you can run standard suspension at the front - no pissing around with ae86 crossmembers etc.
purple_beasty wrote:You tend to find your steering rack is running through your bellhousing then....
Lamphant wrote:so is there anyway to run the steering rack under de 'box or sumtin
