sparkless
sparkless
Postby darkstyle » Mon Jun 13, 2005 8:32 pm
k, my 4age isint getn spark, i've got a new battery, new dizzy, newish spark plugs, new coil lead, replaced coil and ignitor and it still wont spark! :x
thinkn ecu next but bugdiv i know if it aint that, any ideas?
cheers for any help
darkstyle
Postby sergei » Mon Jun 13, 2005 11:02 pm
do you actually have engine light on when you turn on ignition?
Is your igniter earthed?
Check for loose ground points (especially the one on intake manifold, coming from loom)...
Are the injectors firing?
Postby EVLGTZ » Tue Jun 14, 2005 8:56 am
yeah check those earths, not only ignitor but also the main one from that battery. May have come loose when ya changed it over
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby l1ttle_d3vil » Thu Jun 16, 2005 10:36 pm
what sort of car/4age? have you had the coil tested? is there power at the coil?
ive just had a huge mission sussing out why mine didnt have any spark...i had done a conversion though so probably won't be the same problems as urs.
Postby darkstyle » Sun Jun 19, 2005 3:32 am
gah! got it started today, turned out to be that shitty little earth cumin off loom which bolts to intake manifold. mustv missed when i connected it all back up.
it is a ae-82 gt rolla
cheers for the suggestions
darkstyle
