eagle or champion leads on ae111 blacktop?
Postby phatman3801 » Tue Jun 14, 2005 11:31 pm
which are better eagle or champion leads on a ae111 blacktop i can get either brand new at same price just woundering which are better? (they are both 5mm)
phatman3801
Postby AceSniper » Wed Jun 15, 2005 2:57 am
id go for eagle, even tho I havent used or seen them, I do have a set of hardly used champion ones here while they are ok, they dont seam to fit down the plug bore nicely and are slighly to long, they use beldon cable (think) which is good.
AceSniper
Postby matt dunn » Wed Jun 15, 2005 8:29 pm
I can do NGK leads for a 20V for around $115. No idea how that price compares with your prices.
Matt
Postby Al » Wed Jun 15, 2005 8:43 pm
Checked genuine prices as well? Toyota leads from Mr Revhead should be a good price 8)
Al
Postby 10k 20v » Thu Jun 16, 2005 10:29 pm
go genuine :D for that perfect fit
10k 20v
Postby Mr Revhead » Thu Jun 16, 2005 11:40 pm
sounds like a condom add 8O
a lot of toyota leads are around $100
Postby AceSniper » Fri Jun 17, 2005 4:33 am
If the NGK leads are the same as what I have... there right on factory fit and alot easyer to remove and fit :):)
AceSniper
Postby NA Drifter » Fri Jun 17, 2005 3:24 pm
between 2, i'll go for eagle.
found them to have less resistant. Sometimes factory stock item are even better!!
Keith
NA Drifter
