expected power from FM I/C, b bearing trb, link comp
Postby TRDmod » Mon Jun 20, 2005 2:30 am
i was thinking of putting a front mount air to air, on my 205, it has 3 inch ex, cold air in take. and i want to put a bal bearing turbo, run 17 or so psi through a link ecu, dyno tuned.....what sort of power could i get out ofr this engine with out doing the internals, also considering getting a hks head gasket to lower compression for higher boost and to maximise the link tuning....any feed back?
should i get bigger injectors, fuel pump etc?
Domino's Pizza.....
TRDmod
