5AF 4spd to 5spd
5AF 4spd to 5spd
Postby HELBND » Mon Jun 20, 2005 12:57 pm
Hey i currently own a sprinter with a 4sd manual transmission, hydraulic clutch, chassis code AE92. Are there any 5sp boxes that will bolt in with the current mounts? Is there anything other than the box i would need? e.g. selectors... etc.
Any help much appreciated
Ben
HELBND
Postby Malcolm » Mon Jun 20, 2005 2:26 pm
I'm reasonably sure you can just get a 5spd from any fwd A series engine, and it should be a direct swap. Check your chassis plate to see what the transaxle code is, probably something like C40, in which case you want a C5*. I know you can swap from 5spd to 4spd just by swapping gearboxes because I once bought a gearbox from a wrecker that was supposed to be a 5spd but ended up being 4! Worked fine, it was just sh*t
