Getting a KE36 to sit REAL low... what to do?
Postby rollas22 » Wed Jun 22, 2005 2:33 pm
Projects... we all have them
Car in mention is a Toyota Corolla KE36 wagon, need to get it real low, has 17" mags on already.
Any sudgestions?
KE-Corolla's for life!!!
rollas22
Postby pervert » Wed Jun 22, 2005 2:38 pm
Severely low reset leaves in the back, and superlow Kings in the front (compressed another 30-40mm) with aftermarket shorter shocks all round. Easy.
pervert
Postby THA SHZ » Wed Jun 22, 2005 3:41 pm
Makita lowering kit :lol:
Or wot mr pervert said , but in addition after the reset springs then also use lowering blocks , will dump it on its ass 8)
THA SHZ
Postby RunningRich » Wed Jun 22, 2005 3:53 pm
Take the suspension out altogether, sit it on the chassis rails. Clearance is overrated...
Richard
http://gtfour.supras.org.nz
RunningRich
Postby pervert » Wed Jun 22, 2005 3:55 pm
RunningRich wrote:Take the suspension out altogether, sit it on the chassis rails. Clearance is overrated...
I like this guys style... :lol:
pervert
Postby 92GTApex » Wed Jun 22, 2005 4:16 pm
Are YOU asking for advise on how to lower a k series Callum?
Or am I hearing things :lol:
Wouldnt mind hearing a bit more about this project sometime
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby Big pun » Wed Jun 22, 2005 5:12 pm
Im about to lower my KE25 as well on 15" Simmons, anyone know if you can buy shortened shocks off the shelf??
from what ive herd you cant get super low king springs for a 25 so should i just buy low king springs & get them compressed or chop a coil off or what?
Big pun
Postby pervert » Wed Jun 22, 2005 5:35 pm
Compressed, don't chop unless you absolutely have to, and aftermarket shorter shocks should'nt be hard to come by.
pervert
Postby Muzzie » Wed Jun 22, 2005 9:36 pm
92GTApex wrote:Are YOU asking for advise on how to lower a k series Callum?
Logan
Thats not Callum :P
Muzzie
Regular Poster
Postby 92GTApex » Wed Jun 22, 2005 9:39 pm
well if thats not Callum whos posting under his name?
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby Adamal » Wed Jun 22, 2005 10:09 pm
Springs, who needs 'em? ;) Bumpstops work fine!
Postby pervert » Wed Jun 22, 2005 10:11 pm
If you don't need springs, you don't need bumpstops, why stop all that extra drop?
pervert
Postby RS13 » Wed Jun 22, 2005 11:37 pm
If you want to go stupidly illegal low, just take the rear leaves out, and flip them upside down, and maybe cut bumpstops.. but I don't see the point, as 17's would rub like a bitch, and you'd chassis would last about 2 weeks before being ground off!
If you want to do it decently, to a certifiable degree, just get a bit of wood and some u-bolts made up, stick them on the leaves, chop the wood until you get the desired height, take the block to an engineering shop, and get them to make up a metal version, thats the back.. then get some Kings (if you can find them!) or standard ones compressed, take the shock into an engineer, get him to rethread the strut lower. Gives you much less travel, but it's certifiable, I've seen cars with worse get cert! :D
RS13
Postby TrouserFxGt » Thu Jun 23, 2005 8:01 am
RS13 wrote: and you'd chassis would last about 2 weeks before being ground off!
and dont forget cracked.
Alcohol, The cause of and solution to all lifes problems.
H J Simpson.
TrouserFxGt
Postby TygerTung » Sun Jun 26, 2005 9:00 pm
Don't get kings, they are WAY to soft!
Get some custom ones made up, since you won't have $&#$% all suspension travel get some about 175 lbs and then get some good shocks, and you';ll have to get them shortnened.
TygerTung
Postby spencer » Mon Jun 27, 2005 12:24 pm
Big pun wrote:Im about to lower my KE25 as well on 15" Simmons, anyone know if you can buy shortened shocks off the shelf??
Spent heaps of time going through shocks catalouges to sort this out. some of the shortest I found for the rears are hilux fronts Ill have to check what the exact chassis code is. I dont know the diameter of ke25 front shocks but aw11 prefacelift rears work in the kp61 and ae92 shocks in the ae86. Shortening fronts is cheap anyways.
ms63 crown
spencer
Postby 3T-Rona » Mon Jun 27, 2005 8:50 pm
have u seen mikes ke36, 'RX36' the green 13b turbo wagon thats like my dream car lol. hes pretty much semi tubbed the rear end of that, 4 linked a hilux diff. so maybe u need to get the gas a raise the chassis rails so u can slam it even more.
3T-Rona
Postby 1598cc » Tue Jun 28, 2005 1:55 pm
cut fronts, flip rear leafs.. easy as..
1598cc
Postby qik20v » Tue Jun 28, 2005 9:56 pm
if you want low hard springs,
snells springs in auckland make springs
and for coilover-type springs their price was cheaper than an off the shelf item (like kings) and you can choose the spring rate and height of spring
1996 AE111 Toyota Levin BZ-G - 15.1 @ 146km
http://toyspeed.blakjak.net/profiles/profile.php?id=301
qik20v
Postby suberimakuri » Tue Jun 28, 2005 10:12 pm
ke70wagon: i run hilux shocks, kyb code on GD website.
i ran 7 leaves in the rear with blocks.
17" wheels are stupid, too big to go low, and won't follow shape of guard.
your only hope is to add extra leaves and reset the pack (or get blocks), and run stiff shocks.
then the back will be stiff but won't bottom out everywhere on every bump.
front, you want at least 300lbs if you're going that low.
175lb is only 3kg.
suberimakuri
