Phil HELP!! link Igniter in ae101 gt-z levin
Postby trd__levin » Mon Jun 27, 2005 10:10 pm
Here is what i have got off phil for the coil wiring and i need to match it upto this link one can someone please help me!
Here is what phil has said
1, Black - coil output no.2
2, blue - Coil output no.1
3, yellow - Tachometer drive
4, grey - ignition feedback from igniter to stock ecu
5, white - toggle input
6, tan - +12V power
Body of Igniter - Ground.
Here is what the link says that i need to match upto
1, Trigger two
2, Coil two Negative
3, Tacho
4, Earth
5, Trigger one
6, Coil one Negative
Thanks so much if you can help im in the middle of wiring this link lem V5 in.
Shaun
trd__levin
Postby trd__levin » Tue Jun 28, 2005 10:53 am
bump
trd__levin
Users browsing this forum: Google [Bot] and 17 guests
