Ke70 Headlight Wiring Diagram
Postby overcast » Wed Jun 29, 2005 2:06 pm
I'm looking for a wiring diagram for the slant front model ke70 of headlight as I have converted mine into the twin headlight '80 model and need to find out where to wire my high beams into. Any help is much appreciated :)
overcast
Postby z|gen » Wed Jun 29, 2005 2:55 pm
just use a test light and prob the wires to find out which one is your high beam and low beams
AE91 SUPERCHARGED COROLLA
z|gen
Postby fangsport » Thu Jun 30, 2005 10:58 pm
don't the high beams operate on both lamps giving a better spread, therefore, your inner lamp will be wired to the high beam on the outer lamp, it's been a while since i owned a twin headlight DX though. dont the single square model(81-) have a provision for the extra lamps on the loom?
fangsport
Postby matt dunn » Thu Jun 30, 2005 11:21 pm
Your original loom would have one plug each side with three pins.
Plug that back into the outside two headlights.
Then wire across from
the left pin on the outer to the left pin on the inner,
and
the right pin on the outer to the right pin on the inner,
on both sides.
matt
Users browsing this forum: Google [Bot] and 21 guests
