Super Strut Fun
Super Strut Fun
Postby XS1V » Fri Jul 08, 2005 8:29 pm
Hey im just in the process of takeing out my superstrut shocks from my ae101 levin, have managed to take the rears out easy as but the fronts are a bit different :S Undone everything holding the strut in but yea, both sides wont budge. Is there an easy way to take them out??
Also the reason im takeing them out is to replace a few warn ball joints, do i just replace the worn ones or are there other parts i should replace at the same time??
Thanx :)
ST205 Group A Rallye #2363
XS1V
Postby sergei » Sat Jul 09, 2005 9:14 pm
You will have to separate top ball joint (or whatever is that) real pain in the ass, the bestway just buy balljoint puller (~$30 off repco) as try with that...
Good Luck
Postby aesc » Sat Jul 09, 2005 10:53 pm
Yip separating the ball joint is a b**ch, tried to do it once myself and gave up. Also trying to separate the lower arm from the strut can be tricky.
Just out of interest, are you replacing the ball joint that connects the strut to the top of the hub? How much did you pay for the ball joint??
EX AE101 owner
2013 Ford Focus ST
aesc
Postby XS1V » Sun Jul 10, 2005 7:52 pm
Yea im going to buy a ball joint puller tomorow. I have to replace one of the uppers and one of the lowers on the other side, im paying 80 each for the upper ball joint
Should i be replaceing anything else due to general wear?
XS1V
Postby RunningRich » Mon Jul 11, 2005 11:04 am
Top ball joint:
Two heavy steel hammers/mallets. Hit the steel (on the strut) either side of the balljoint in unison and it will soon pop.
Bottom balljoint:
Tapered long prybar placed between lower arm and small link arm (from memory). One good hard smack and it will pop too.
Mine has been out a few times so I have the knack now.
Richard
http://gtfour.supras.org.nz
RunningRich
Postby 92GTApex » Mon Jul 11, 2005 11:50 am
Dumpty sledge hammer is good for this job...
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby aesc » Wed Jul 27, 2005 3:50 pm
RunningRich wrote:Top ball joint:
Once you pop that top ball joint, how do you go about getting it back in to the suspension carrier/hub?
And I suppose both top and bottom ball joints would need to be cracked to replace the top joint right?
EX AE101 owner
2013 Ford Focus ST
aesc
Postby XS1V » Wed Jul 27, 2005 5:08 pm
I have got mine all done now and you shouldnt need to pop both top and bottom to just change the top. To put it back on you just lever the hub down to hold ball joint tight, works well
XS1V
