4age extractors
4age extractors
Postby ae92levin » Wed Jul 13, 2005 6:06 pm
will 4age 16v extractors fit a 4agze? i think they do im just not 100% :?
Now: 94' Mark II grande; 92' gt starlet ha
then: x3 4agze ae92; 4agte ae92; e30 bmw
ae92levin
Postby fx'dwagon » Wed Jul 13, 2005 6:12 pm
i was told when selling mine that they will but there is one bolt which is different which is at one of the ends so you need to modify that somehow
fx'dwagon
Postby EVLGTZ » Wed Jul 13, 2005 6:22 pm
pretty sure that the 16v ones are all interchangeable whehter ze or plain old 4age.
Its the 20v ones that need redrilling
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby ae92levin » Wed Jul 13, 2005 7:05 pm
fx'dwagon wrote:i was told when selling mine that they will but there is one bolt which is different which is at one of the ends so you need to modify that somehow
i was told that they do fit up, but i think the cas gets in the way?? hrrrmmm thx 4 the replys keep em coming !
ae92levin
Postby SaM » Wed Jul 13, 2005 7:53 pm
They fit
Eagles may soar, but weasles dont get sucked into jet engines...
SaM
Postby Mr Revhead » Wed Jul 13, 2005 9:10 pm
they are the same part......
Postby ae92levin » Wed Jul 13, 2005 9:39 pm
thankkkkkkkks
ae92levin
Postby soopachargen » Tue Aug 02, 2005 3:33 pm
what about 20v extractors?? will they fit onto a gze? there is a guy selling some coby 4age extractors and said they foul the CAS... is that just coz they are a different design?
When in doubt, down and out.
soopachargen
Postby wanado13's » Tue Aug 02, 2005 3:40 pm
Coby extractors for the 4age do not fit on a 4agze sweet because the cam angle sensor gets in the way of one pipe. I know this because I bought some and am now selling them on trademe because they won't fit unless you modify the pipe by the cam angle sensor.
wanado13's
Postby ChaosAD » Tue Aug 02, 2005 6:14 pm
DONT get coby extractors for a 4age/ze theyre junk.
Perhaps 20v extractors, but ive heard that the starter motor has to be on the inlet side for them to fit.
ChaosAD
Postby fx gt » Tue Aug 02, 2005 6:46 pm
ChaosAD wrote:DONT get coby extractors for a 4age/ze theyre junk.
how are they junk?
fx gt
Postby ants_ae92 » Wed Aug 03, 2005 9:16 am
Starter motor doesnt have to be on the inlet side. They still fit, although very close. Ive done this myself.
And yeah 2 outer bolt holes need to be modified for the 20v ones to fit. Also custom secondaries f your using 20v extractors.
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1548
Current Ride: ae101 1997 White corolla BZ-touring station
Previous Rides: ae92 Levin (smallport 4age, Lowered, 17s, exhaust, intake). Ke70 Station wagon (4k, lowered)
ants_ae92
Postby aesc » Wed Aug 03, 2005 9:52 am
how are they junk?
Theyre not mandrel bent for a start
EX AE101 owner
2013 Ford Focus ST
aesc
Postby soopachargen » Wed Aug 03, 2005 11:53 am
what length and size secondaries would i want with a 4agze, with bluetop cams, bigger pully etc if i was to go with 20v primaries??
soopachargen
Postby Mr Revhead » Wed Aug 03, 2005 12:03 pm
500mm i think is about where it should be
Postby ants_ae92 » Wed Aug 03, 2005 1:03 pm
So what effect would having a smaller length secondary give?
Compared to a longer secondary?
ants_ae92
Postby ChaosAD » Wed Aug 03, 2005 1:25 pm
My mate put some on and lost power.
Extractors are usually tuned for peak torque but the coby's are tuned to a bit over 7'000rpm on a standard engine :?
The pipes are not matched to the plate that bolts to the head very well
I rang coby to ask why they were tuned to 7,000 and what testing they had done on them. I was informed thay the extractors were built to be easy to build and easy to fit to the car. They are not purposely tuned to any rpm and no dyno testing was done.
Thats for the fwd 16v 4age extractors, rwd may be a different story.
Your wasting your money and Hp with extractors on a 4age unless you have a modified engine and get custom extractors made up.
ChaosAD
Postby Mr Revhead » Wed Aug 03, 2005 1:40 pm
yep, unless your pushing over 200hp, stock ones are fine.
do some research on exhaust pulse tuning
Postby Brick » Fri Dec 30, 2005 2:39 pm
my mate has some 20v headers i can have my me ze, is there a differnce between blacktop or silvertop headers? and how hard is it to make them fit?
Brick
I know Kung Fu
Postby Mr Revhead » Fri Dec 30, 2005 2:46 pm
yes, blacktop ones are a larger diameter.
all you have to do is notch the 2 outer holes in the manifold.
if you have engine apart some port matching would be an idea too
Users browsing this forum: Google [Bot] and 22 guests
