EDITED deistinguishing features of a ct20 and a ct20b
Postby SIDE_FX » Fri Jul 15, 2005 4:14 pm
how can i tell the diff is the code printed on the turbine housing???, wat is the actual difference between a ct20 and a ct20b, like will they both produce the same power
SIDE_FX
Postby vvega » Fri Jul 15, 2005 4:23 pm
they look nothing like each other
the ct26 has ct26 written in big letters on the compressor
v
vvega
Postby Al » Fri Jul 15, 2005 5:36 pm
this is a ct20b exhaust side. It has 7 studs. the ct26 has 6
this is the front housing
Al
Postby Dell'Orto » Fri Jul 15, 2005 5:38 pm
Compressor wheels look very different too, the CT20b has like 2 fins on each blade, the CT26 doesnt
Postby SIDE_FX » Fri Jul 15, 2005 7:33 pm
SIDE_FX
Postby Malcolm » Tue Jul 19, 2005 1:25 pm
ct20's are nothing like ct20b's. a ct20 would be a downgrade from your ct26. ct20's are single entry and ct20b's are twin entry
Postby THA SHZ » Wed Jul 20, 2005 9:40 am
wot about a ct20 that has twin outlets but only four studs at the rear ? :?
THA SHZ
Postby Malcolm » Wed Jul 20, 2005 9:51 am
never heard of such a thing, but if it's only got 4 studs (assuming it's not a 7 stud flange missing 3!) then it's still a ct20 and it still sucks arse
