AE101 TRD Short Shifter
Postby BigDon » Fri Jul 15, 2005 9:46 pm
I have just got a TRD short Shift for my AE101 except that I got sent a AE92 model.
Could some one with an AE101 Short/S scan and email ((johnlove@xtra.co.nz)) me the instructions that came with theirs so I can compare the parts. As I dont want to trouble my mate by sending it back and it fits but the AE92 spacer plates wont fit because they are triangular and 3 bolts and I need rectangular and 4 bolts but this seems to be the only difference. So I was just going to make my own to the right specs.
BigDon
Postby DXROLLA » Tue Aug 25, 2009 7:40 pm
Can you still get these for the ae101 levin?
DXROLLA
Postby Mr Revhead » Tue Aug 25, 2009 7:53 pm
no.....
Postby DXROLLA » Tue Aug 25, 2009 8:06 pm
Is there any other ones available?
DXROLLA
Postby bluemaumau » Tue Aug 25, 2009 8:55 pm
is'nt there some mod you can just do to your selectors?
Postby jakesae101 » Tue Aug 25, 2009 9:54 pm
do you want to sell said short shifer
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby DXROLLA » Tue Aug 25, 2009 10:13 pm
No im looking at buying one just wondering what brands are available if any or if i would have to get something made up
DXROLLA
Postby neo » Wed Aug 26, 2009 1:51 pm
You can shorten the throw quite easily.
The TRD short shifter lengthens the main shaft by 10mm and then uses spacers between the plastic housing and the metal mount.
I also added 10mm to the fore and aft movement as well :)
neo
