1jzgte in2 a 1987 gz20 soarer
Postby jamie kennard » Wed Jul 20, 2005 6:57 pm
hey guys any ideas on what problems ill run in2?
i give my wife a quarter inch at a time. for those 10 seconds or less im free
0211354229
jamie kennard
Postby deaf_rattle » Wed Jul 20, 2005 6:58 pm
mounts and wiring will be the 2 main things.
Also bellhouing and gearbox depending on what you want to use.
jz manual stuff isnt cheap
Postby jamie kennard » Wed Jul 20, 2005 7:08 pm
gona do the mounts myself an ive orderd the apropriate bellhousing 4 my w series box. Also going to use a vl commodore fuel pump an surge tank, keeping the standard pump as a lifter pump.
0211354229
jamie kennard
Postby KE20 » Wed Jul 20, 2005 7:46 pm
the sump may be a problem, depending if its from the soarer or the chaser, ie: sump in the middle or sump at the front.
KE20
