What is involved, to upgrade to the later model SW20 brakes?
(eg. putting later model brakes on Gen 1 SW20)
Is it simply a case of getting late model rotors and calipers, and bolting them up?
(obviously you will need to bleed the brakes, and you may aswell replace seals etc. and give them a clean while they are out of the car.)
Or is it more complicated then that?
Also what exactly is different?
Just larger diameter rotors, or are the calipers different too?
Are there secondary changes which occured too, such as increased diameter brake lines?
Cheers.
Dave.
