CosmoNz wrote:wut sorta car u got?
peas wrote:I'm about to do the same thing. Though I have downloaded some instructions on how to manufacture a $15 FCD using a potentiometer and a few resistors if you want them. I have searched for it on the net but can't find it anymore unfortunately. It also details which wires need to be tapped but this is for a SW20 so I'm unsure if it would correspond to a ST185. Then again plugging the manifold-MAP sensor line sounds cheaper still but you lose the protection that the fuel cut provides... if that bothers you.
fivebob wrote:CosmoNz wrote:wut sorta car u got?![]()
Another classic CosmoNz post, you can't really be that stupid can you???
To answer the original question, that's overboost fuel cut coming in at approx 12psi, either lower your boost, fit a Fuel Cut Defencer (FCD), or disconnect and plug the line going to the MAP sensor from the manifold. On Gen II 3S-GTEs such as your ST185 it's only used for fuel cut, and to run the stock boost gauge.
FoRsaKeN wrote:A diode in the MAP sensor line??
Yea, i wouldn't mind raising the fuel cut by a little bit....1 diode raises it how many psi, you know???
CozmoNz wrote:fivebob wrote:CosmoNz wrote:wut sorta car u got?![]()
Bugger off, that said "boost cut" when i first saw that post. NOT st185
and his signature, well... i dont read them.
sh*t happens.
FoRsaKeN wrote:i don't want to be running lean the closer i get to the fuel cut threshold
Al wrote:FoRsaKeN wrote:i don't want to be running lean the closer i get to the fuel cut threshold
You wont ever run lean on the stock turbo.
