ae92 trueno vs ae92 corolla, will the suspension mate?
Postby Psycho_Dad » Wed Jul 27, 2005 1:30 am
ok i just bought some dobinsons front springs and monroe front reflex strut inserts from a dude with a ae92 corolla nz new(4a 1500cc carby powered jobbie)
question is? will these inserts and springs mate with my 1989 ae92 trueno struts? if not i can return them, but i would really like some decent front suspention for my runabout
any ideas? if they dont fir do you think the ae92 corolla gti(i think its a gti) struts(whole thing) would fit into a ae92 trueno
any light shed on this would be terribly appreciated
Psycho_Dad
Psycho_Dad
Postby THA SHZ » Wed Jul 27, 2005 9:37 am
they are the same between the levin and the corolla , but the top stut hats may be slightly different , no biggy . But in ur corolla do u have standard shocks or aftermarkets , as some of the aftermarkets are a sealed strut not one tht requires an insert , so check this b4 commitin to it 8)
THA SHZ
Postby Psycho_Dad » Wed Jul 27, 2005 9:49 am
i got TEMS factory suspension, that harden/soft junk that says its working when really its not
16 year old suspension, would they have inserts?
thanks heaps
Psycho_dad
Psycho_Dad
Postby THA SHZ » Wed Jul 27, 2005 10:00 am
im not 100 % sure but i think those werent actually inserts , have a look on the struts and see if there is a nut at the top of the strut where the shaft for the shock comes thru 8)
THA SHZ
Postby Psycho_Dad » Wed Jul 27, 2005 10:10 am
u the man tha shiz, u da man
THANKS HEAPS, i be jacking her up in a few hours
if they dont take inserts, could i rob some other shocks from like an fx or somthing and put em in?
Peace
Psycho_Dad
Psycho_Dad
Postby THA SHZ » Wed Jul 27, 2005 10:18 am
u can get front standard shocks from an ae82 tht r inserts which is wot i believe they possibly are for but if u use tht then u will also have to use the hubs with it but tht aint a bad thing cause then u get adjustable camber in the front if u use them 8)
THA SHZ
Postby Psycho_Dad » Wed Jul 27, 2005 2:20 pm
ok well it turns out that i undid the bolt at the top of the shocks and oil pissed out of them, now theirs some plate with 3 or 4 holes in the top staring at me.... and the inserts seem to be a good 8mm skinnier than the shocks themselves???
so im turning to the options
a)replace oil that spilled out with gear oil, reassemble so i can pick my g/f up at 3
b) keep gutting the suspension, keeping in mind that i may end up with completely unrepairable shocks and struts, i have to drive 175kms tonight
c) take the shock to a shock shop, inwhich im very confident they will tell me it wont fit anyway
d) what you recommend, i dont know jack about this, wish i did
im losing time,
Peace
Psycho_Dad
Psycho_Dad
Postby TRD Man » Wed Jul 27, 2005 3:08 pm
It's not uncommon for the inserts to be narrower than the body of the strut you're putting them in.
Try installing them and tightening the nut down. If there's no movement in them they should be OK.
TRD Man
Postby Psycho_Dad » Wed Jul 27, 2005 10:59 pm
yeah i gutted them, turns out the cartriges are 5mm(approx) longer than the struts, anyone know where i can get longer threaded top nuts(thats so the incorrect term but im sure you guys know what im talking about) to hold the buggers in?
again thanks for all the help thus far
Psycho_Dad :wink:
Psycho_Dad
Postby THA SHZ » Thu Jul 28, 2005 10:38 am
Go to george stock and co , but u will need to know the thread type as there is three different types , or if u can take in the sample and they will be able to get it from tht 8)
THA SHZ
Postby Psycho_Dad » Thu Jul 28, 2005 2:29 pm
mint will do when i get the time, any idea what that will cost?
Peace
Psycho_Dad
Psycho_Dad
